Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
There are lift brackets bolted to the head , one in the rear drivers side above the thermostat housing, the other on the passenger side front above the serpentine belt idler pulley area.
