Starter solenoid voltage
Hi, Got a 2008 no crank issue. I can hear plunger on starter but its not turning engine. I took starter to autozone and it tested good. I have battery voltage on red starter cable but have about 1 or less volt on solenoid wire connector.
Whats the spec for solenoid wire connector during cranking? |
Not sure, but I would think it's more than 1 volt. In the old days(my days:roflol:)
I thought the solenoid switch received 12 volts. Just for kicks. Check all your battery and chassis grounds before you have to trace that wire back to the source. |
