Starter solenoid voltage
Old Nov 27, 2012 | 12:26 PM
raj49's Avatar
Hi, Got a 2008 no crank issue. I can hear plunger on starter but its not turning engine. I took starter to autozone and it tested good. I have battery voltage on red starter cable but have about 1 or less volt on solenoid wire connector.
Whats the spec for solenoid wire connector during cranking?
Old Nov 27, 2012 | 02:41 PM
Not sure, but I would think it's more than 1 volt. In the old days(my days)
I thought the solenoid switch received 12 volts.
Just for kicks. Check all your battery and chassis grounds before you have to trace that wire back to the source.
2005HHRauto
2.0L Performance Tech
Jul 3, 2016 10:44 AM
rad1steve
Dec 18, 2013 11:12 AM
2007HHRLT
Feb 8, 2013 07:17 PM
chingchonger
Jul 20, 2007 02:57 PM
