Sticking door locks
Old Nov 26, 2012 | 08:43 PM
Racing 729's Avatar
Question Sticking door locks
Having a issue with the power door locks sticking on the rear doors. Any quick fix ideas out there?
Old Nov 26, 2012 | 08:44 PM
skyline26's Avatar
most likely the actuator is getting weak..try replacing it if you stil have warranty or dont mind spending the money..or try making the whole bigger where the pin comes out of
Old Nov 26, 2012 | 08:54 PM
Sometimes, if you remove the door panel and the reinstall it, taking very good care where the rods are supposed to ride. There is a slidey surface that the rods are supposed ride against, sometimes the rod gets off of the "guide". Especially true if the panel has been removed and carelessly re installed.
Old Nov 26, 2012 | 09:50 PM
Rod's Avatar
Rod
I am having the same problem with the passenger front door with my 2008 - it takes 2-3 "clicks" to open and does not lock reliably on the first click
Old Nov 26, 2012 | 10:02 PM
These locks are known to sometimes stick as they get some age on them.
My quick fix: Grab the lock knob by hand. Work it up and down 20-30 times to free it up. A little lube down the rod hole as a last resort.
Old Nov 26, 2012 | 10:04 PM
skyline26's Avatar
replace the actuators
Old Nov 27, 2012 | 05:29 PM
voigtsga's Avatar
I am having the same issue on my '08. All 4 actuators have been tested by the dealer and verified that they aren't working right. It is very aggravating to have to hit the FOB 4-5 times to lock/unlock, etc. I am about the replace them all myself. http://www.gmpartsoutlet.net has the cheapest price shipped I can find on them. 20791792 is LF, 20791793 is RF, 20791794 is LR, and 20791795 is RR.
Steve 1948
Sep 17, 2013 04:45 PM
lionelgilbert
Feb 25, 2012 10:36 PM
jcgc50
Jun 25, 2011 09:15 PM
rubics_cube
Feb 28, 2011 05:54 PM
hillbillypimpin
Jun 2, 2010 07:35 PM
