Starting issue plus weird smell
When you say it don't start is it trying to start or nothing when you turn the key, no click no noise at all. Do headlights dim when you turn key to start. If all this is ok it might just be starter relay not engaging starter. just my 2 cents
Most of the time I dont hear any noise starting it when its doing that. Only sometimes I might hear a click. But it has its days. Hasnt even done it today or yesterday. But there are days it takes me like 6 times to start it.
Had my starter and battery checked today. Both are fine. The guy was thinking the starting problem is a recall from 2006. So Ill deal with that later. But now I need about $150 for wheel bearing, they said that was the smell.
Don't let that bearing/hub go too long before replacing it, if it fails completely you could possibly lose the wheel on that corner, since its getting hot enough to smell you're going to need it changed A.S.A.P.
