Steering
Steering
Has anyone noticed a tendency for the HHR to pull to the left. My 2009 with 2.2 engine and 5 speed manual transmission has always exhibited this tendency, not very much but slightly. Tire wear does not indicate any abnormality.
I moved your post to problems and repair.
I have not noticed this per say but I have noticed that mine is sensitive to different types of tires. My aggressive winter tires wander much more than my summer tires.
There have been a couple of incidents reported - give the SEARCH tool at the top of the page a go, and search for "steering pulls to the" (without the quotes of course) - https://www.chevyhhr.net/forums/problems-service-repairs-42/steering-pulls-left-39518/ might be a good start for you.
Interesting but two people does not make a trend I suppose.
I should have written 'wanders' to the left rather than pulls to the left. I have been driving FWD vehicles for years and I do not think this is torque steer. Even on very light or no throttle it wanders left. Perhaps if the left drive shaft was driving at that time it would go left a bit as would the right shaft go right. Perhaps the left shaft is the predominant driving shaft. The shafts are different lengths and diameters also designed to prevent torque dominance. Their angles they run at are likely different too.
But I can see a bad LCA bushing or a bad Wheel Hub exacerbating the issue to the point of annoyance.
