struts replaced still front end noise
ok ... had a front end knocking type noise when one drove over an irregular service bump or etc.... so they replaced the struts..... both of them. i still have the noise but not so loud..
any suggestions. by the way they were replaced under extended warranety i have an 07 50,400 miles |
Front sway bar links? Steering column? I've had both those replaced, along with both struts. Each time it would fix the sound, but then would come back. Hopefully this last time will fix it for good.
i took it back and they took it on test drive... ended up replacing the front sway bars... (think thats what it was called)
noise gone |
Front End Clunking
Have had front end clunking twice on 2007 LT. Stabilizer bar links were first replaced at 22,000 miles and again May 2010 @ 47,000 miles. Both times solved clunking problem. Shottenkirk Chevrolet in Quincy, IL performed the second replacement under warranty. No cost to me.
