struts replaced still front end noise
Old Apr 29, 2010 | 05:38 PM
HHR4JK's Avatar
ok ... had a front end knocking type noise when one drove over an irregular service bump or etc.... so they replaced the struts..... both of them. i still have the noise but not so loud..
any suggestions.
by the way they were replaced under extended warranety
i have an 07 50,400 miles
Old Apr 29, 2010 | 05:50 PM
urbexHHR's Avatar
Front sway bar links? Steering column? I've had both those replaced, along with both struts. Each time it would fix the sound, but then would come back. Hopefully this last time will fix it for good.
Old May 6, 2010 | 11:05 AM
HHR4JK's Avatar
i took it back and they took it on test drive... ended up replacing the front sway bars... (think thats what it was called)
noise gone
Old May 7, 2010 | 07:21 AM
QCYMAS's Avatar
Front End Clunking
Have had front end clunking twice on 2007 LT. Stabilizer bar links were first replaced at 22,000 miles and again May 2010 @ 47,000 miles. Both times solved clunking problem. Shottenkirk Chevrolet in Quincy, IL performed the second replacement under warranty. No cost to me.
Scarfoot
Nov 30, 2014 08:36 PM
nortonneon
Feb 3, 2013 08:41 AM
Putter
Jun 30, 2012 02:20 PM
purity D
Dec 29, 2011 09:58 PM
rnorth6920
Jan 22, 2009 09:15 AM
