Stuck Key at 328miles 2010 HHR Panel
Supprize! When I stopped to park my new 2010 HHR Panel leftover with only 328 miles on it, the key got stuck and I could not get it out. It was stuck in ACC position. So I just got through reading 4 pages of stuck keys and decided to join this forum. It's great. Thanks. But the stuck key still goes on.
Sorry to hear your having a problem already but welcome to the site if it has happened before some one will likely come to help you.
:welcome3: :welcome3: :welcome3: |
On the bottom of the steering column you'll see a little square door hatch. Pop that open with a screwdriver, and inside there you should feel a little release switch. Flip that and your key will come out... But you'll need to get it fixed by the dealer, that hatch is just a way to get the key out when it gets stuck. Until it gets fixed, you'll have to keep opening up that square to reach in there.
Many threads on stuck keys. In the Search function type in "stuck ignition" and you find about pages worth of threads.
Welcome..... & wut they said ^^
