Stuck oil filter cap
Old Nov 30, 2016 | 03:27 AM
Danman03's Avatar
Well, as usual I decided to work on my car and something went wrong. I was doing a routine oil change and the oil filter cap is stuck. The cap has rounded off to where the socket isn't getting the grip it needs. I really don't feel like spending hundreds of dollars at a shop for a $15 part. So, does anyone have any DIY tips? I was thinking of piercing the cap and then using a screwdriver and hammer to see if I can get it loose. Another option I saw was to heat a 31mm socket and basically melt it onto the cap. Any help would be greatly appreciative!
Old Nov 30, 2016 | 07:08 AM
Channelock pliers worked for me
The OEM cap is 32mm but can get rounded of if you use an adjustable wrench or 1 1/4 inch socket
Old Nov 30, 2016 | 07:45 AM
aradmahogany's Avatar
Order this first!!!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Nov 30, 2016 | 08:36 AM
Danman03's Avatar
I tried the channel locks, but can't get it to budge.
Danman03's Avatar
Originally Posted by aradmahogany
I already have an oil filter
Old Nov 30, 2016 | 09:03 AM
Yes but that comes with the oil filter cap.
Old Nov 30, 2016 | 10:09 AM
And it is cheap for the combo! you will get a basically free filter for the next oil change and you will get the OEM green oil filter cap O-Ring that (debated by some) doesn't need to be changed with every oil change. I have gone through many oil changes since buying that cap and not a hint of a leak without changing the o ring.
Old Nov 30, 2016 | 10:11 AM
On top of that, unless you did it and dint realize, I would go to wherever you last had the oil changed and give them a few words... and not go back there after that LOL
Old Nov 30, 2016 | 11:25 AM
Danman03's Avatar
Yeah that's what I'm thinking of doing. I'm probably 75% sure the shop I took it to last cross threaded the cap back on. I took an impact wrench to this sucker and it still won't budge. I just called a tow and I'm going to take it a shop
Old Nov 30, 2016 | 12:21 PM
Who rounded the cover off?
If it was cross threaded it should be leaking.
I would be thinking drilling a hole across the "nut" part big enough to put a screwdriver through then twisting.
It is plastic, so breaking it is an option.
Get the correct tool for the future. It is listed in the aforementioned Amazon link.
