Sunroof
I bought a 2008 HHR this weekend, I opened the sunroof but now it will not close all the way. Is there anything I can do to close this manually? Please let me know
Clear any debris out of the tracks and check the wind deflector for damage
Make sure the rails are clean and unobstructed. No manual over ride.
Originally Posted by Oldblue
(Post 940081)
Probably the wind deflector is broken or there’s stuff in the track
https://www.chevyhhr.net/forums/how-...overage-11629/ |
Are you doing this with key on? Have you checked the fuse (#10 under hood)? Make sure NO fuse in #11 under hood.
Does the motor make a sound, like trying to work? Is it in the Vent position or stuck somewhere else? Is it up or down? Did it stick when the key was turned off while it was moving? Will it go either way with help? |
Originally Posted by donbrew
(Post 940186)
(Post 940084)
Here are 2 snippets from the shop manual that might help:
https://cimg6.ibsrv.net/gimg/www.che...8201f6d259.png https://cimg7.ibsrv.net/gimg/www.che...a63c88a158.png |
There is a short section in your Owner Manual (link in my sig) that might apply.
