Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
After many searches through the forums I determined that the front driver side leak I've been having is most likely a problem with the sunroof drains.
I pulled down the headliner and felt vindicated when I saw that the drain had indeed popped off and was just emptying into the headliner.
...and then was completely baffled when I looked for the hose to reattach. There isn't one. It's not there. It's not at the top near the sunroof, it's not running behind the front windshield support trim, it's not attached to the door grommet. It's entirely absent.
I pulled everything off the passenger side to make sure- on that side it's still attached, everything is there where I expect it to be.
I'm not exactly sure what my question even is besides "what gives??" Has anyone else found this? Is it easy to install a new hose? Can I just plug that drain and hope the other three can keep up?
Water poured into the sunroof gutter flows out here.
X2 on the new hose. You can get bulk tubing at just about any hardware store for a few dollars. Take a look and see if grommet #3 is there. If so, it may be as simple as just connecting the new tubing on both ends.
Thanks for the helpful responses everyone! I did actually have some body work done on that corner (got hit in a parking lot about two months after I bought it) so it would make sense that it walked off around then.
Every time I have had an insurance claim the repair was guaranteed.
Greggs whole rear end is "warrantied for life" including the exhaust system from when I was rear ended. Normally if you bring it to one of the insurances "approved repair shops" they will give you a lifetime warranty for as long as YOU own the vehicle, assuming you will get rid of it soon. Id just check with them before anything else.
