Sunroof won't slide back
My sunroof will open to the vent position just fine, closes, but will not slide back. The driver side of the sunroof starts to move, but not the passenger side so it gets slightly angled and stops. I have been unable to find any diagrams on how this mechanism is set up, so if anyone has any suggestions or pics of the sunroof mechanism it would be greatly appreciated.
The guide for the pop-up mesh air deflector gets broken. Then it jams up the works. I have no idea if that's your problem. You could try "helping":it get open by gently pulling back on the side that's sticking. If you can get it open, you can inspect the deflector track. The deflector pops out easily, and if the broken deflector track is the problem, once you remove it, the window should operate fine.
Have you heard of GoOgle?
Here is a result to this very site. https://www.chevyhhr.net/forums/how-...overage-11629/
There are a few vids on youtube, here is one (from a chevhhr.net member). https://www.youtube.com/watch?v=uPFD...unto%27sGarage
Just in case you may have confused the post following mine with my original post, here is mine in it's entirety for your perusal:
"My sunroof will open to the vent position just fine, closes, but will not slide back. The driver side of the sunroof starts to move, but not the passenger side so it gets slightly angled and stops. I have been unable to find any diagrams on how this mechanism is set up, so if anyone has any suggestions or pics of the sunroof mechanism it would be greatly appreciated."
Now, I can see how the first response to mine stating how the screen may have jammed my sunroof could have befuddled you, and I am trying to see if I can help the sunroof open to inspect it, but seriously, I was expecting better from you.
Remember, help that doesn't help, isn't help.
Seems your sunroof may have a broken drive cable or a foreign object in the track
A used parts source
http://www.partshotlines.com/parts/c.../sun-roof.html
A used parts source
A used parts source
A used parts source
Poking around with a magnet, and I found a tiny piece of metal that is hook shaped, may be what the cable hooks to. Would be great if there was a breakdown of the sunroof mechanism somewhere, but all I find are rough drawings of the entire sunroof assembly. I guess it's considered non-repairable like everything else these days. Looks like I'll be going to the boneyard after all.
They might not include the exact fix you want. But, they give a good idea how the thing works, which is what you asked for, with moving pictures.
There are a lot more on youtube, I didn't care enough to look past the first 2.
Maybe facebook would be more help.
I just glad it broke in the closed position.
First I discovered that I could open and close the sunroof by moving it in small increments while manipulating the deflector. (I have long arms.) Then I realized that just removing the deflector allowed normal opening and closing. Driving without the deflector sucks tho.
