Tail gate door release w/no battery
The basic prinicple here is that voltage has been made availible to the electrical circuit. It just has been inserted into the circuit in a different location then the battery location. The circuit is still intact and functional.
Yeah, it's a pretty simple cable. It only has pins at 4 and 5 (chassis ground and signal ground) and 16 (battery positive). It can also be used to keep the radio presets, clock, etc. when the battery is removed.
Cool - actually 07ashhr, it doesn't need to be that long - just long enough to plug it into the OBD2 port, and plug the other end into the cigarette lighter (maybe 2 1/2 feet would do it). ;-)
