Tail light access panel loose
Old Feb 8, 2010 | 08:16 PM
jonathanm's Avatar
My drivers side tail light access panel won't stay in place, it falls out constantly. Is there an easy fix? I hate to bug the dealer about something I could take care of myself easily.
Jonathan
2008 HHR MM5 AA5
Old Feb 8, 2010 | 09:33 PM
RFT's Avatar
RFT
If you look at the panel, do you have two plastic stems protuding from the opposite side of the notch? If one, or both of those are missing, you will need a new panel. Otherwise, not trying not be a jerk but just make sure those stems go in first before closing the other side of the panel.
Old Feb 8, 2010 | 11:35 PM
jonathanm's Avatar
I'm not sure what you mean by "stems", but IIRC, there are some plastic bits that engage towards the front of the vehicle, and you swing the panel shut like a door that would hinge on those bits. The problem is the hole seems to be bigger than the panel, so there is no friction on the side towards the rear to keep it closed. It just kind of flops in there, and flops right back out at the slightest bump.
Old Feb 8, 2010 | 11:50 PM
Perhaps look at the other side to compare & see if anything is missing on the falling out one.
stems = tabs = hold it in thingies
Old Feb 9, 2010 | 02:10 AM
prod's Avatar
Go to the dealer and ask to try one from another HHR in yours, if that works then get a new one.
Its also possible that the interior quarter panel is warped, that would be a lot more trouble.
If it were me though, Id try to macguyver some kind of clip to the old one.
Old Feb 9, 2010 | 06:28 AM
Jeff®'s Avatar
Super glue?
Old Feb 9, 2010 | 06:35 AM
solman98's Avatar
Originally Posted by Jeff®
Super glue?
Then you wouldn't be able to open it up when you needed to.
Old Feb 9, 2010 | 08:07 PM
IgottaWoody's Avatar
epoxy in some tabs behind the main panel then add a small piece of velcro..not too much or it will be hard to pull apart
Old Feb 10, 2010 | 07:53 PM
ChevyM84's Avatar
sometimes the tabs at the other end(not the hinge oart) warp.......really theres nothin to do but try to bend them back out but dont try too hard or u will break it......i would just take it to the dealer(i love bothering dealers)
Silverfox
Maintenance and Upkeep
Jun 8, 2015 02:09 AM
HHR14all
"How To" Tutorial Library
Dec 15, 2014 04:43 AM
Dutchman09
Jun 25, 2010 05:27 PM
