Tailpipe knocked off center
I think my daughter hit it with the trailer when backing up. She admitted when she was backing up she turned too sharp and kinda jack knifed it. 😒
oh well. None of the insulators are gone or loose. I just changed all the motor and tranny mounts. I’m now in the process of changing the water pump, a tie rod and both control arm bushings. Lol. Then I’ll get on the tailpipe. I just thought since I’m under there anyway might as well have an eye on what “right” looks like so I can maybe see what is “wrong”. 👍
ill try to get some pics later when I get a chance of the flex pipe and the under carriage. Maybe others will see it where I can’t.
love to get kudos
i started working on my cars long ago. doing my own oil changes and brakes and little things. Then a little at a time I got into bigger and bigger stuff. Then, ten years ago, my daughter and I bought a real junker and rebuilt it. It was nothing special. No collector car. Just a little tool around car it wouldn’t hurt if our repairs weren’t perfect.
She was supposed to help. But she didn’t enjoy it as much as I did. So I did it myself. Coil packs. Head and valve cover gaskets. Pumps. Fans. Sensors. Suspension. Transmission. You name it. I laid hands on it. 🤣
Today, I don’t trust others to do as good a job as I will do. Not all bad. Just I care more about it cause it’s mine.
Example. Just a few months ago, I had brake pads in my back seat when I was getting tires changed. When the tire guy saw them he said he’d change them while the tire was off for nearly nothing. So I said ok. But, I told him there had been a lag brake so make sure to clean and lube the slides and check the calipers. He said ok and I let him do it.
Anyway. When I was still getting lag the next day, I took it apart and the slide pins were gummy and one caliper boot had a huge tear in it. Also my rotor on one side was chewed up. 😒 I was upset. But more at myself for letting this guy do it “to save time”.
Anyway. I’m sure most DIY home mechanics do their own work for the same reason. Lol. I just happen to be a woman diy mechanic. 😁
love to get kudos Kimberly- (May I call you Kimberly ?) I think most of us do too..
i started working on my cars long ago. doing my own oil changes and brakes and little things. Very Cool. My Dad started me at about 6 years old wiping off his tools. Then a little at a time I got into bigger and bigger stuff. I would say so.. Then, ten years ago, my daughter and I bought a real junker and rebuilt it. Great bonding project, sounds like to me.. It was nothing special. No collector car. Just a little tool around car it wouldn’t hurt if our repairs weren’t perfect. Sounds ideal.
She was supposed to help. But she didn’t enjoy it as much as I did. Well, everyone has their own likes etc. So I did it myself. Coil packs. Head and valve cover gaskets. Pumps. Fans. Sensors. Suspension. Transmission. You name it. I laid hands on it. 🤣 Awesome, I admire your 'go-get it ' attitude..
Today, I don’t trust others to do as good a job as I will do. I can 100% relate to that. Not all bad. Just I care more about it cause it’s mine. That is my feeling as well.
Example. Just a few months ago, I had brake pads in my back seat when I was getting tires changed. When the tire guy saw them he said he’d change them while the tire was off for nearly nothing. So I said ok. But, I told him there had been a lag brake so make sure to clean and lube the slides and check the calipers. Smart Gal.. He said ok and I let him do it.
Anyway. When I was still getting lag the next day, I took it apart and the slide pins were gummy and one caliper boot had a huge tear in it. Also my rotor on one side was chewed up. 😒 I was upset. But more at myself for letting this guy do it “to save time”. Well, he showed his true colors to you,Green for quick money. And lesson learned.
Anyway. I’m sure most DIY home mechanics do their own work for the same reason. Lol. Yes I would absolutely agree. I just happen to be a woman diy mechanic. 😁 That is Awesome..
Quick story, that's how I met my Mrs of 26 + years. We both rode, & still today ride Harleys, she was doing the oil & service on her Harley, I offered to help, & the rest is history..
You are welcome. Yes, Kimberly will do. Only a few close friends believe I do this all myself. Well. Friends and the people at the parts store. 😋.
Love hearing about a loving marriage. That is fantastic. So few marriages last nowadays. Does she do her own maintenance still? Still ride?
Had a tiger today trying to get one control arm off. 🤬. The bolt turned but wouldn’t back out. I spent the entire day trying every way I ever knew to get it out. And since I’m not changing the arm. Just the bushing, I couldn’t cut it off.
I was about to loose my mind so I looked online and read that control arm bushing could seize on the bolt. Well, I thought, that can’t be it. The bushing has no threads. Right?
Wrong. 🤪 The bushing is totally shot. Was turning with each swing. So I got a hefty lock wrench. Got tight grip on the bushing and my daughter came out to hold the bushing tight while I broke it loose.
Not much better than that feeling when u overcome an obstacle. It’s just awesome. 👍
Tomorrow I’ll be getting the bushings swapped then I can put the suspension back together and get her drivable for a bit. Going to do a full flush of the coolant lines before I put the new water pump in. Don’t want any gunk in there with a new pump. I gotta drain it all anyway. Might as well start clean. 😊
Yes it’s always a great feeling getting the job done, and you know you did it yourself and correctly! Are you using the water pump tool or changing the timing chain and balance shaft chain as well?
