Third brake light not working
Old Jan 13, 2021 | 12:58 PM
phoenix708's Avatar
To answer:
A.0036, 0054, 0140, 0141, 0700
B. Yes, all the bulbs are working. Stock filament bulbs.
C. Gotcha. New relay did the trick for the lights. Also, cleaned bulb, and socket connections.
Old Jan 13, 2021 | 02:45 PM
Just read these causes and possible solutions
https://www.obd-codes.com/p0036
https://www.obd-codes.com/p0054
https://www.obd-codes.com/p0140
these are all common to O2 sensor problems, the common thread is burnt connections, so inspect it closely and the ground wires.
https://www.obd-codes.com/p0700
this one can also be related to a loose or broken ground wire.
Old Jan 13, 2021 | 02:52 PM
Trouble codes have a letter before the number. B,C,P, etc
Tell us the full code number.
Old Jan 13, 2021 | 04:28 PM
I surmised them to have the letter P
Old Jan 13, 2021 | 08:59 PM
phoenix708's Avatar
Sorry......yes a P before them.
Old Jan 13, 2021 | 09:01 PM
Is there some reason you don't just replace the #2 O2 sensor or just check the wires and fuse (#33 under hood)? All of those will inhibit cruise and a lot of other things along with the P0700..
Old Jan 13, 2021 | 09:31 PM
phoenix708's Avatar
I just scanned it this afternoon. I initially just did some searching to see the usual causes that people ran into. When I get a chance I will read through what Oldblue put up as well as try your suggestion. It is an older car but low mileage.
Couple years ago I started it, and it was missing really bad. Turns out squirrels got under the hood, and ate through 2 of the fuel injectors wiring harness. That was a bunch of fun to splice back. They chewed it within a half inch of the injector. Nature at its finest......oh joy.....hehehhehe
Old Jan 13, 2021 | 09:44 PM
Then they got to wire to the #2 O2 sensor and the TCM.
Old Jan 13, 2021 | 10:11 PM
phoenix708's Avatar
Yea, no kidding........... .... We will see......
Old Jan 14, 2021 | 08:03 AM
Look for traces of Frank’s Hot Sauce! Squirrel’s put that stuff on everything!!
Lol!!
