Originally Posted by bigwillyg
(Post 723153)
Well, it was definitely the starter. I pulled the old one out and the gear inside was sliding back and forth, and pieces of magnet/inductor were falling out slashing with what looked like a cover or shield that was cracked. Once I swapped it, the car started immediately. It drags now and seems to waste a bit more gas but it may be that my tires are low too. Would a p0341 obd2 code have anything to do with that?
here's a link for the code. Sounds like a CPS is either bad or poorly connected. Starter should not drag, ever. |
Originally Posted by donbrew
(Post 723160)
http://www.obd-codes.com/p0341 here's a link for the code. Sounds like a CPS is either bad or poorly connected. Starter should not drag, ever. |
So, apparently my camshaft position actuator solenoid is what's failing. Although dealer fears possibly loose timing chain, my money is on the solenoid.
The code of P0341 refers to the Crankshaft Position Sensor, not the Camshaft Actuator Solenoid (which would be typically indicated by a P0010/11 or P0013/14) - you might want to check into that a bit deeper.
Originally Posted by whopper
(Post 746905)
What was the code? The code will point to the specific solenoid as per the how-to article on how to replace them: https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Man, that is a great write-up!!! ;) |
(Post 747055)
Man, that is a great write-up!!! ;) The Chevy dealer diagnosed it. |
Thing is, there is no THE there are two. Which one is bad?
(Post 747085)
1/2 hour job in the driveway - and $50 for the part and it be done. :)
