Top or bottom Engine Replacement
Old Sep 20, 2013 | 11:06 PM
bduemig's Avatar
I threw a rod today on my 2008 HHR 115K miles. 2.2 automatic.
I found a low mile engine, same year, same In engine id (D).
My question is, can I pull the engine from the top or does it have to come out the bottom? Anyone know where I can find a manual for engine removal?
Old Sep 21, 2013 | 12:55 PM
Check your PM.
Old Sep 21, 2013 | 01:06 PM
You beat me to him Don, once again I doff my hat to you.
Old Sep 23, 2013 | 02:54 PM
bduemig's Avatar
Well, I ordered a replacement engine today (18K on it). The picture seems to show that one of the heater core lines off the water feed line is kinked. I imagine that I can use my old one for that but I can't find any reference to seals for the water feed line.
Any suggestions on that and on what thermostat to use?
Old Sep 23, 2013 | 04:07 PM
bduemig's Avatar
Another Question. The new engine has a water pump on it and the engine has 18K on it. Should I trust that it is ok or should I change it? If so, which brand of pump do you recommend?
Old Sep 23, 2013 | 04:13 PM
If it really has 18 K, I'd trust it. Brand doesn't make much diff, get rebuilt (they come with seals usually) about the same price, arount $40-$50. Look at the one you are getting, some have a plastic impeller which may make a difference to you.
Old Sep 23, 2013 | 05:19 PM
bduemig's Avatar
That is what I was thinking. Thanks for the help.
Old Oct 3, 2013 | 10:58 AM
bduemig's Avatar
Well, I got my new engine. It guides in next week. One problem. There is a crack on the block for one of the oil pan bolts. Looks old, maybe original build. I'll try to add s pic when I get to my computer
Old Oct 6, 2013 | 09:13 PM
voigtsga's Avatar
115k is awfully low mileage to have a thrown rod. I wonder what caused that?
Old Oct 7, 2013 | 04:24 AM
PaperChaseHHR's Avatar
Lead Foot Syndrome.. JK, Either way that sucks, I hope everything goes smoothly for you!
