Torque Converter Clutch Solenoid replacement
Hi folks, glad to be a part of the Community!
I have a 2008 HHR LS, 2.2/auto. just over 100,000 miles now, overall car hasn't been that bad at all through the years, since new! The car runs/shifts/stops/accelerates just fine, no issues, except losing the lockup on the converter. Car does go through all the gears just fine... just that with losing the lockup for whatever reason, the rpm's are up slightly on the highway. Is it possible, it is just the Solenoid, and could I try replacing it- to regain my gas mileage............ :/ And if so, RockAuto has #4 of them, from 17 to 100$, Transmaxx, ATP, and Pioneer...................... any thoughts would be very helpful on which one?!! Again, many thanks, glad to be a prt of the group-at-large!! :) Sincerely, Bob. |
Got any trouble codes stored in the ECM?
Debunker...
One other thing to look at is the "O" ring on the Turbine Shaft. If it's worn flat (100k miles is pretty well its limit).. it could be the cause of your loss of Lock-up. Clare |
Why not have it diagnosed by a competent trans shop? That would be cheaper than throwing parts at it.
Welcome to the site, yes X2 first question.... any codes? , if so what are they? Some times a battery lobotomy will reset the TCM and restore normal driving. |
Re: Torque Converter Clutch Solenoid replacement?
Hi again folks,
I haven't seen the check engine light at all..... I have an OBD 2 scanner, I'll check and see. If it is the turbine shaft o-ring, does the trans have to come out of the car for replacement??! And yes, I did think of trying my cheap little scan tool before bringing it in the shop.... the vehicle is due for trans fluid and filter replacement, so I figured I would try the 17$ clutch solenoid from RockAuto?! Cheap enough.................. And I will try to disconnect the battery for a bit, cant hurt at all- right?!! :) I do appreciate all the help so far people, thanks a lot!! I've been a mechanic for many decades, but got out of it around 2000. I still do what I can for my car, my girls car, etc. etc. I'm an old MoPar guy, BUT- I like anything old with METAL bumpers.................. lol! ;) Sincerely, Bob. :) 70 Superbee 67 Newport 72 NewYorker 77 Fury Wagon (first car, I loved that thing!) 95 Tercel 98 Camry 88 Bronco 2 (not necessarily in this order...lol!) |
In your owners manual, the transmission fluid is a life of vehicle fill, unless you drive a lot of rough dusty nasty backroads, or stop and go severely tough city driving. |
