TPMS problems.
Old Apr 26, 2012 | 08:13 PM
Snoopy's Avatar
"freak".....
The sensors occasionally have transmission and reception problems. Happened to me a couple of times on different vehicles. No matter how hard you work at the programming procedure, it just will not read one of the from a tire.
I took mine to the dealer and they reset it with their Tech II. Takes maybe 10 minutes. Didn't cost anything. You're under warranty.....take it to the dealer.....no big deal.
I doubt if you are having trouble with a battery. Everyone I know gets between 5-7 years.......almost like my Delco
Old Apr 26, 2012 | 09:33 PM
Pinballfreak's Avatar
Ran out of warranty about 4000 miles ago.
Old Apr 27, 2012 | 10:58 AM
Originally Posted by Chevy13
Lol, I love all of the ChevroletCustomerService responses on this forum. It should just be automated by not. "I will not offer any help at all, but I do hope you find a solution"
I apologize, if my posts are upsetting you. This is not my intentions.
I hope you have a great weekend.
Old Apr 27, 2012 | 07:17 PM
Originally Posted by Pinballfreak
Alright, I redid the reprogramming this evening and everything went normal until I got to the last tire. It would not register with the system. I redid the reprogramming three times, each with the same result. I take it that the sensor is dead on the right rear. I am due for new tires any ways, so I'll just go ahead and get some new sensors while I'm at it. Is there a certain kind I have to get or are they pretty much universal?
If you were doing the correct sequence, then the one giving the bad reading should be the one to not reset. If the RR is the one showing -- in the DIC, then that's where the reset should end, not the LR (which should be the last). LF, RF, RR, LR.
And no, not universal, be prepared; a tire store will be getting upwards of $80 each (and buying from the local GM dealer) + install. You never have given year, I assUme it's 2008-2009. Before and after might be different.
Old Apr 27, 2012 | 10:28 PM
Chevy13's Avatar
Lol....
You too...
Old Apr 28, 2012 | 05:43 PM
Sorry if I wasn't clear on what tire. It's the left rear tire. Thanks for letting me know that they are not universal. I have a 2010 model.
Last edited by Pinballfreak; May 1, 2012 at 09:30 PM. Reason: got my left and right mixed up
Old Apr 30, 2012 | 10:35 AM
Lol....
You too...
I hope your weekend was very enjoyable as mine went by way too fast. LOL
Old Aug 20, 2015 | 08:15 PM
mr123go's Avatar
What ever happen with your sensors? Because I'm having the exact same issue exactly. None of mine are reading after attempting the reset.
Old Aug 20, 2015 | 10:10 PM
Lucky's Avatar
Did one of the sensors read incorrectly before you did the relearn procedure?
If so you will need to replace the bad sensor before you can relearn the sensors correctly.
Old Aug 20, 2015 | 11:49 PM
mr123go's Avatar
Yes, but here's the thing, the right front was reading incorrectly. Even when I got my tires rotated, the right front was still reading incorrectly. It kept showing that the pressure in that tire was low but it wasn't. Yesterday the warning light came on saying it was too low. When I checked the pressure it was fine, that's what made me look problem up in the manual and tried the reset. Now it's not reading any of the tires now.
