Traction Control
Old May 6, 2012 | 08:43 PM
Speedrazer69's Avatar
Question Traction Control
My car has traction control coming on and off regularly which changes the shift pattern to a very uncomfortable level. any ideas would be appreciated
Old May 6, 2012 | 09:20 PM
badassbowtie's Avatar
ABS sensor is my thought. should throw a code i think.
Old May 6, 2012 | 09:55 PM
Have the codes read and then proceed. It should definitly have a code stored if the traction control is engaging regularly.
Old May 6, 2012 | 10:54 PM
X 2
Have your codes pulled and post 'em up here, otherwise our guesses would be just that....guesses.
Old May 7, 2012 | 02:26 PM
What is the year and trim level of your HHR?
Old Jan 27, 2013 | 07:16 PM
safetyjedi's Avatar
I keep having the same problem with the service traction warning coming on but by the time I get to the auto parts store, they cant find the code because the light is off. I have been told it might be related to the oxygen sensor or abs sensor. And ideas?
Old Jan 28, 2013 | 03:45 PM
Lucky's Avatar
You will have to get the codes read by a scanner that will communicate with the abs and traction control. Most part stores just have a code reader the will just read code for emissions. At least that what I have seen in my local part stores.
Old Jan 28, 2013 | 04:00 PM
ChevyMgr's Avatar
You are correct. That's why they can't see the code.
Old Jan 28, 2013 | 07:45 PM
db/sb's Avatar
This is another one of those threads started by someone who never came back to see the answer. He hasn't been active here since 8 minutes after posting.....
Old Mar 28, 2013 | 12:43 PM
safetyjedi's Avatar
I really need an answer to this as well. It happens everytime I idle for a long time say 2 minutes, then the traction control light comes on. If I clean the throttle body it seems to clear it for about a week, can you clean the fuel injectors? I noticed a lot of corrosion on the fuel rail also. Should I replace it? I am about at my wits end.
