trans cooler lines
any tips tricks i can pass on to a shop.......they have replaced the lines and fittings but they still leak at the fittings.....they are hinting that the stud is stripped the holds the lines
Originally Posted by extanker
(Post 862404)
That stud is long, they could slide a spacer then the nut. Did they replace the seals at the transmission? Apparently they did something wrong like not open the seal centre. https://www.chevyhhr.net/forums/driv...e-seals-49041/ |
(Post 862409)
Yes. Tell them to fix it correctly. Not sure what part is supposed to be stripped but a decent shop would replace parts that need be. You're paying for it. Tell them to do the job right.
(Post 862440)
gee why didn't i think of that..........nothing gets by you hommie
Originally Posted by donbrew
(Post 862443)
Indeed! Why not?
The stud in question goes thru the hole in the middle of the bracket, A remove stud and replace, or as I said put a small spacer on the stud an use the clean threads up the stud . https://cimg5.ibsrv.net/gimg/www.che...7e514cbab2.png |
