trans cooler lines
Old Mar 13, 2019 | 10:42 AM
extanker's Avatar
trans cooler lines
any tips tricks i can pass on to a shop.......they have replaced the lines and fittings but they still leak at the fittings.....they are hinting that the stud is stripped the holds the lines
Old Mar 13, 2019 | 10:52 AM
Yes. Tell them to fix it correctly. Not sure what part is supposed to be stripped but a decent shop would replace parts that need be. You're paying for it. Tell them to do the job right.
Old Mar 13, 2019 | 11:29 AM
That stud is long, they could slide a spacer then the nut.
Did they replace the seals at the transmission?
Apparently they did something wrong like not open the seal centre.
https://www.chevyhhr.net/forums/driv...e-seals-49041/
Old Mar 13, 2019 | 03:51 PM
extanker's Avatar
gee why didn't i think of that..........nothing gets by you hommie
Old Mar 13, 2019 | 05:44 PM
Indeed! Why not?
Old Mar 13, 2019 | 06:00 PM
extanker's Avatar
Originally Posted by donbrew
Indeed! Why not?
i did and nicely so as to not give him an attitude.......i just asked for some tips from here......ya know like a forum is supposed to do....like help
Old Mar 13, 2019 | 07:31 PM
The stud in question goes thru the hole in the middle of the bracket,
A remove stud and replace, or
as I said put a small spacer on the stud an use the clean threads up the stud .
OldSwede
Drivetrain (Excluding Engine)
10
Aug 6, 2018 09:41 AM
KZig
Aug 9, 2015 01:21 PM
Cat Man HHR
Dec 28, 2014 10:18 AM
Tyler Harvey
May 14, 2014 06:02 PM
upOnGamE
Aug 4, 2006 06:23 PM
