Transmission cooler lines
Old Dec 26, 2014 | 12:23 PM
Cat Man HHR's Avatar
Hi
My tranny cooler lines are getting wet. I called the dealer and made an appointment to have it fixed. The dealer said this is a common problem. Has anybody else had this issue with their HHR? I have 22,000 miles on my 2010.
Thanks
Old Dec 26, 2014 | 12:26 PM
prod's Avatar
Originally Posted by Cat Man HHR
Hi
Thanks
A few have, its more likely the seals going into the rad, take a closer look.
Old Dec 26, 2014 | 04:23 PM
Mine turned out to be the seals at the rad end of the hoses
Old Dec 26, 2014 | 04:47 PM
Thanks for your input on this
Would there be a part number of the O ring?
I could pop it apart and do the repair myself instead of going through the hassle of dealing with the dealer.
Old Dec 26, 2014 | 05:07 PM
taz3's Avatar
This may offer some insight.
AUTOMATIC TRANSMISSION OIL COOLER PIPES. Fits: Cobalt, G5, HHR, Malibu, Malibu BASE 4 DR NOTCHBACK, Malibu LS 4 DR NOTCHBACK, Pursuit | Nalley Buick GMC Brunswick
Old Dec 26, 2014 | 05:20 PM
The release tool will cost less than $2.
Give the Commonly Used Part Numbers - Chevy HHR Network thread a look, it may be there already.
Old Dec 26, 2014 | 07:07 PM
I used a small flat blade screw driver to gently release the horseshoe clips
Old Dec 26, 2014 | 07:23 PM
prod's Avatar
Doesn't show detail for the top connection in that diagram, is it the same parts for top and bottom seals?
Old Dec 26, 2014 | 09:45 PM
#8 is for upper and lower tube to rad trans cooler
Old Dec 27, 2014 | 03:23 PM
Is #8 the fitting that holds the o-ring that can leak?
If it is, can the o-ring itself be changed?
A picture of that part itself would help.
I do have o-rings at work that are used for hydraulics and can match up the seal if need be.
