Transmission problems
Old Jan 6, 2022 | 04:55 PM
jagipm0710@gmail.com's Avatar
Can I just add marvel mystery oil to transmission and crank it up and let it run through for a few minutes?
Old Jan 6, 2022 | 04:57 PM
Of course you can. It’s your HHR, but I don’t advise it, it’s not going to correct burnt out solenoids.
Old Jan 6, 2022 | 05:05 PM
Burnt out solenoids? Is there a how to tutorial on checking transmission levels?
Old Jan 6, 2022 | 05:13 PM
Is there a puddle under the car, that's the only place fluid can go.
https://www.chevyhhr.net/forums/how-...-change-58325/
Old Jan 6, 2022 | 05:40 PM
Yes there is... Which is new to me....🙄
Old Jan 6, 2022 | 06:53 PM
Is that puddle a reddish fluid?
is that puddle the size of a quarter? Or larger?
if you look up under the transmission do you see where the leak is , where the fluid is coming from?
could it be the output shaft seal leaking on the passenger side?
gio89kid
2.4L Performance Tech
23
Jan 19, 2019 10:43 AM
DIESAHL
Maintenance and Upkeep
7
May 22, 2018 09:44 PM
Drifter..
Jan 18, 2018 03:04 PM
brown1243
Mar 4, 2012 10:19 AM
mistrfixitman
Oct 21, 2010 08:57 AM
