Trouble with my DIC
Old Dec 14, 2010 | 08:46 PM
Rikki Sixx's Avatar
Trouble with my DIC
2008 HHR Panel. The outside air temp reading seems to be stuck on 30 degrees. Whatupwidat? Everything else reads fine. Anything I can do on my own?
Old Dec 14, 2010 | 08:52 PM
Uma's Avatar
Uma
Many Threads on this, and I am not the guy the ask, lol. It is not a problem with your car..it is the same problem that we all have. Todd (Uma)
Old Dec 14, 2010 | 09:09 PM
THE BATMAN's Avatar
I here viagra helps . ?
Only the second time using the dancin bat , Whoa.
Old Dec 14, 2010 | 09:12 PM
Rikki Sixx's Avatar
I should have known that was coming.
Uma's Avatar
Uma
Too funny! Todd (Uma)
Old Dec 14, 2010 | 09:24 PM
Sounds like the outside temperature sender might have packed it in. Its located in the right front, kinda buried as with most things on the HHR. I'll grab a cup of coffee and the shop manuals to see if there are any things that are quick and easy to check.
Old Dec 14, 2010 | 09:35 PM
This is one of those "gonna need a scan tool" deals, from reading the manual it looks like the temp sensor is bad. You do need a scan tool to check it though, or take it to the dealer. Since the reading is stuck it looks as if the sensor has failed and is giving a reading based on a short to ground.
Old Dec 15, 2010 | 08:44 PM
IgottaWoody's Avatar
I dont have that problem...will the cure still help?
Old Dec 16, 2010 | 12:55 AM
seems like sometimes the D I C just has a mind all of its own
Old Dec 16, 2010 | 07:51 AM
diskullman's Avatar
My D I C needs no introduction, Yo D I C barely even function
