tugging my car and off in the morning
Old Jan 16, 2014 | 01:35 PM
jesus4092's Avatar
In the mornings when I move about two or three blocks, to stop my car as it throws a change and off, only happens once, and then not turn off or jarring, sometimes tugging but not off, only happens once on the day or if much time parked. someone has this happened?
also hear a noise when changing from second to third and then is removed, what may be? my car is a 2006 automatic HHR
Old Jan 16, 2014 | 02:05 PM
skyline26's Avatar
ummm
chugging? like shaking/stalling feeling?
bad gas? injector cleaner depending on mileage? fuel pump/filter?
need more info, and better english..im kind of confused
skyline26's Avatar
is the check engine light on? try a code reader, maybe something is stored in memory
Old Jan 16, 2014 | 02:20 PM
jesus4092's Avatar
Hi, yes is shaking, after shut off, i turn on again and dissapear the problem.
I use gas premium, i cleaned the inyector before ( this problem cause before T/C problem), the filter pump im not remember change, the manual not especific the change ¿ where is located?
The engine ligth is off
Old Jan 16, 2014 | 03:22 PM
Lucky's Avatar
If I'm understand correctly you want to know where the fuel filter is.
The fuel filter for the hhr in in the fuel tank and normally is only changed when replacing the fuel pump.
If possible you should get the codes read so we have a place to start.
Old Jan 16, 2014 | 03:24 PM
Jesus. I see you're in Mexico. We're losing something in the translation. Could you try posting up in Spanish. Someone on this site will be able translate for the English speaking members.
We would like to try and help with your problem.
Old Jan 16, 2014 | 03:42 PM
Lucky's Avatar
Firemangeorge that a great idea.
Old Jan 16, 2014 | 04:01 PM
Radco's Avatar
Jesús. como George dijo tu mensaje en español, podemos traducirlo por ti, para que podamos ayudarle. Bienvenido al grupo, una grieta en el inyector puede causar un problema como tu, también tienen los códigos sacaron incluso si la luz del motor no se enciende. Buena suerte.
Good idea George. I have Google Translator saved so I can chat with in laws :)
Richard
Old Jan 16, 2014 | 04:16 PM
jesus4092's Avatar
Muchas gracias por su ayuda, les explicare en español.
Por las mañana enciendo la HHR y recorro unas 2 o 3 cuadras, al momento de detenerme por completo jalonea el auto y se apaga, como si trajeras el auto en segunda y no bajara a primera. lo enciendes y se le quita el problema, como que se calienta bien la transmicion y ya no falla.
Noto que cuando arrancas y hace el cambio de segunda a tercera se escucha un ruido como si raspara algo y luego se le quita. es una HHR 2006 automatica, según el mecánico reviso el nivel de aceite y esta bien.
Last edited by jesus4092; Jan 16, 2014 at 04:22 PM. Reason: En ocasiones no se apaga solo jalonea.
Old Jan 16, 2014 | 05:33 PM
Radco's Avatar
Thumbs up
Jesús, tu bienvenida, feliz de ayudar. Esperanza usted consigue su HHR fija
OK gals/guys Jesus issue in English
Update in English
QUOTE = jesus4092; 732684] Thank you for your support, I will explain in Spanish.
In the morning I turn on the HHR and I walk about 2 or 3 blocks, when tugging completely stop the car and off, as if you brought the car down to second and not first. turn it on and you remove the problem, as it is well heated and the Transmit no longer fails.
I notice that when you start changing and makes second-third heard a noise like something and then scrape it off. 2006 HHR is an automatic, according to the mechanic I check the oil level and it's fine. [/ QUOTE]
