Turn Signal Chime – not loud enough!
I know the turn signal chime comes out of the left front speakers via the radio. The radio output is controlled by the low speed serial link, not the high speed CAN, via the Body Control Module(BCM).
Now, what can be done to increase the volume? Is there some programming of either the BCM or the Radio that can be done? I have been leaving the turn signals on just too much, especially when the rain makes it harder to hear. It would seem there would be some adjustment for this. I know I have seen old type flasher relays that have increased noise makers built in being sold to the older, harder of hearing crowd. I have read other posts where people wish to turn their turn signal chimes off or don’t care if they loose it after replacing their stock radio with an after market radio. I do value my chimes, when I can hear them! This is a 2009 LS. |
when my brother installed new speakers and amplified them in his cobalt it made the chimes really loud
ChevyMgr,
Results from above link to older thread did not seem to work. No change in display or the three chimes. I have one of the newer Delphi radios if that makes a difference. RPO Code of radio is US8 with UW5 & U2K. 2009 LS base radio. Turned ignition to Run(before the crank position) waited for the current chimes to stop(no seat belt warning) and pressed and held the 6th preselect button(as counted left to right) for 30 seconds. No luck. Thanks |
Originally Posted by Sno White
(Post 365423)
ChevyMgr,
Results from above link to older thread did not seem to work. No change in display or the three chimes. I have one of the newer Delphi radios if that makes a difference. RPO Code of radio is US8 with UW5 & U2K. 2009 LS base radio. Turned ignition to Run(before the crank position) waited for the current chimes to stop(no seat belt warning) and pressed and held the 6th preselect button(as counted left to right) for 30 seconds. No luck. Thanks Here is what the 2009 manual states: Chime Level Adjustment The radio may be used to adjust the vehicle's chime level. If the radio can be used to change the volume level of the chime, press and hold the sixth numbered pushbutton or the sixth FAV pushbutton with the ignition on and the radio power off. The volume level changes between Normal and Loud. The selected volume level appears on the radio display. Removing the radio and not replacing it with a factory radio or chime module will disable vehicle chimes. |
Yes, the radio was off; only display was the current time.
I have read that Owners Manual front to rear how did I miss those instructions - don't answer that! The thing that bothers me is that word "If" in the second sentence of the instructions. Sounds like some "can't" be adjusted. |
(Post 365432)
Relived to hear you got the same result, well sort of.
Nothing I found on the DIC using the steering wheel controls. |
I know it wont make you happy but try this link:
https://www.chevyhhr.net/forums/show...19&page=21#208 |
Darn. What I suspected.
Thanks for trying! |
| All times are GMT -5. The time now is 08:01 AM. |
