Turn signal relay fuse
Old Apr 15, 2023 | 12:19 PM
mactheneck's Avatar
Originally Posted by donbrew
Did the turn signal used to work? What happened just before it stopped? ANY work done? ANY after market installations?
It acted up like it had a weak connection i.e. it worked/didn't/worked/didn't and so forth till it died completely. Same thing happened to my headlights and temperature control. But after we metered they both came back on as if the circuit tester removed some rust or something. But that didn't work with the turn signal. No after market installations.
Old Apr 15, 2023 | 02:42 PM
Try tightening the bolts in the under hood fuse box. They need to be very tight, past the "afraid its gonna strip" point. I am guessing that at some time the fuse box was removed. Check ALL of the fuses and relays in both fuse boxes make sure they are all fully seated.
Old Apr 15, 2023 | 03:02 PM
mactheneck's Avatar
Now that you mentioned it, we did remove the fuse box when we replaced the master cylinder (brakes). I'll check first thing tomorrow morning. Thanks so far, I'll take it from there.
Old Apr 15, 2023 | 03:09 PM
If the bulb works with flashers, but not turn signal, the diagram I have (Haynes manual) seems to point to the BCM.
Old Apr 15, 2023 | 09:13 PM
But the wires connect in the fuse box. And there were other electrical oddities.
You know how I am about the BCM.
Old Apr 15, 2023 | 10:42 PM
Yes, I know. I just see one wire for each corner exiting the BCM, and each is shared by the turn signals and flasher. So I'm thinking by the time the wire gets to the underhood fuse block, if it was a bad wire somewhere after the BCM, neither turn signal nor flasher would work. I dunno...
Old Apr 16, 2023 | 05:10 AM
mactheneck's Avatar
Bolts are tight. Thanks for the diagram. I will open the fuse box and look at the wires, especially the dark blue one.
Old Apr 16, 2023 | 07:56 AM
I would take the stalk apart and jump wires to make sure we are not chasing rabbits.
Old Apr 16, 2023 | 10:17 AM
But if it were the stalk, wouldn't that affect both front and rear?
Old Apr 16, 2023 | 02:39 PM
Just stabbing in the dark.
