Vent canister connector
I have a 2009 LT with 2.4 engine. I have repaired the pigtail that connects the vent canister to the under body connector some time ago but it is faulty again. I removed the pigtail and tested for continuity and found there wasn't any on either wire. So I took the wires out of the loom and found the wires broken. I separated both wires where the breaks were so that there are now two sections. One section has the small connector that plugs into the valve and the other to the body connector.
While carrying the small connector to my work bench the white wire broke off near the connector so I can't splice another wire to it. I've looked for a new pigtail at Rock Auto. The GM OEM one they sell looks close to the one I have but the larger connector that plugs into the body connector is a little different. The GM pigtail looks short in their picture too with no specs on the length given. I have attached pictures of my connectors. I tried to download the GM picture but had not luck. Would I need an adapter to use the GM pigtail? https://cimg5.ibsrv.net/gimg/www.che...572b6e25b6.jpg Vent canister connector to canister https://cimg6.ibsrv.net/gimg/www.che...fc5ba19176.jpg Vent canister connector to under body connector |
The for sure fix is to get the adapter they sell for 2006-2007 cars that get a new valve. 2006-2007 had a different connector the replacement valve is a new design.
If you have an adapter something is strange. 2088-2011 the body harness should plug directly to the solenoid. However, find out what is causing the short circuit and why there was no code to tell you. One of these at autozone, the Dorman one is the adapter, just cut the harness end off. https://www.autozone.com/electrical-...eVehicle=false |
I don't have any adapter with this pigtail. Just the connectors in the pictures and wires between them and it does plug directly from the body harness to the canister. I do have the P0449 code. I don't think there is a short. This is the code I had before and when I repaired the wire. The code cleared and stayed off for quite a while.
If there is no short what caused the melting and burning?
There was no melting or burning. The white wire just broke off at the canister connector. It seems the wire was just worn out. Nothing was melted.
Your first pic, the terminals are black. They're not burned?
How do wires "just wear out"? Something has to make the brittle.
https://cimg9.ibsrv.net/gimg/www.che...962bebee8f.png |
No, they are not burned. They are made of black plastic; the same as the outer housing on the connector. There is some dirt as well but the connector is not burned or melted.
I'm betting you should replace the vent solenoid. Wires wear out from carrying too many amps a frazzled solenoid can pull excessive amps.
Originally Posted by donbrew
(Post 930098)
| All times are GMT -5. The time now is 01:54 AM. |
