vibration
Old Jun 30, 2019 | 09:52 PM
zumrodrs's Avatar
vibration
I have a 2011 2.2 liter hhr with automatic tranny. I am having an engine/tranny vibration. When I put the tranny in reverse the car is vibrating. I can also feel it when in Park, Neutral or Drive but not as bad. It also seems to get a little worse if I have my foot on the brake. It also happens in reverse and drive with the e-brake on. I am wondering if I might have a vacuum leak. I can not feel it when the car is moving.
Old Jun 30, 2019 | 10:01 PM
I would look at the flex pipe or maybe trans/motor mounts. Why would you suspect a vac leak?
Old Jul 1, 2019 | 07:41 AM
It could be a transmission mount or upper engine mount, the source of the vibration.
Old Jul 1, 2019 | 09:28 AM
Doc brown's Avatar
X2 (or 3?) that's the most likely cause. Yes, it could be a vacuum leak, which would cause a vibration, but that's not as likely. I haven't had a vacuum leak on a car in many years. Hoses are made so much better than years ago that's it's rare.
Old Jul 1, 2019 | 11:05 AM
Hmm what about the brake booster vacuum hose? Is the fitting cracked off ?
paireno
Jun 25, 2008 08:02 AM
paireno
Jun 1, 2008 12:45 AM
vschriver
May 14, 2008 11:26 AM
xzombiex66
Mar 28, 2007 05:44 PM
Rickh
Oct 13, 2006 05:21 PM
