Warped rotor..
Old Sep 20, 2007 | 11:42 AM
solman98's Avatar
Originally Posted by Goose
Thats when you bring it to a local shop and have it done right for a lot less $$ or better yet do it yourself...from what I can gather replacing the rotors on the HHR is pretty straight forward
Goose
Dealer will never see mine out when it's out of warranty or non-warranty work.
Old Sep 20, 2007 | 12:23 PM
mikiec's Avatar
Dealer took care of the warped rotor under warranty.
Mike.
Old Sep 20, 2007 | 12:26 PM
Snoopy's Avatar
Mike.
Mike, pull a wheel and see if they cleaned the hub of rust, as I indicated in my other post. If they didn't I would bet that you'll have the problem again....I hope, for your sake, you do not.....but...
Old Sep 23, 2007 | 12:10 AM
BUtchk's Avatar
When I first got my car it was great then I started to get a shimmy when I started to slow down from highway speeds. It was deemed warped rotors I took it back to the dealer and they turned the rotors free of charge.
Old Sep 24, 2007 | 02:08 AM
270weatherby's Avatar
This is a common problem for rotors that were not bedded properly. Here's a link for procedures from Hawk (they produce high quality pads for street & track).
http://hawkperformance.com/performance/burnish.php
It's hard to do this with an off the lot car as you never know who's test drove it, how many times they stopped, etc. But if you ever swap rotors & pads, it's good to bed your new brakes.
Old Sep 24, 2007 | 03:43 PM
Snoopy's Avatar
Really good advise, 270weatherby,
That procedure is part of MY "Whip" schedule.
BTW ....your forum name.......really nice weapon.
Old Sep 24, 2007 | 04:03 PM
hvrod's Avatar
after market rotors will help..
Old Sep 24, 2007 | 04:35 PM
stevflo's Avatar
Had mine turned under warranty and not there is a swooshing noise in the front in from time to time. They looked at it again the other day and decided they need it back again to take more time to figure out what the noise is. My wife is over there now and they are supposed to give her a car to use. I wonder what that will be???
Old Oct 2, 2007 | 12:31 PM
mikiec's Avatar
Snoopster..
Rotors clean and shiny.
Mike
Old Oct 2, 2007 | 04:58 PM
TomsHHR's Avatar
Wow, I must of got a different batch of steel in my rotors. Hitting 35,000 and still no problems. Mabie it helps to drop the anchor with the long rubber band to stop.
