Water on the Floor !!!!!!!
06 LT 5 Speed...........
After sitting in the Rain For a While........I got about an Inch of Water on My Passenger Side Floorboard :confused: Upon Further investigation..........The Water is coming from some where Underneath the Dash............Drip Drip Drip :thumbsdow ??????????????? |
Do a search for water leak. Others have had this same problem.
hhr has multiple causes for leaks
i still haven't fixed mine . my my local dealer/service manager promised he will fix. a member here -chevymngr- sent me all the gm service bullitens about the leaks. i think they are posted here somewhere. your dealer should fix , without problems. since it is a well documented problem.
Can we say, "class action lawsuit?" Only problem is, they won't acknowledge that until the car is WAYYY to old and out of warranty.... like my Lumina. The intake gasket went out TWICE on it, and then they do a CAL....but of course my car is too old! And the paint peeled off of that car, yet again...too old.
Times like that, makes me hope they go under...lol |
if its comin from under the dash it has to be the gasket under the cowl cover. if it is make sure they replace it not just repair it.
hey guys i had the same problem but on the drivers side, after heavy rain the left side of the carpet gets wet but my driveway is also at a decline. The dealer said its from a wire loom that runs thru the firewall water drips down the inside of the wire loom and onto the carpet but after they claim to have fixed the problem it still happened so maybee there full of it!!!
yes and no
Originally Posted by masterchief1112
(Post 359268)
2006 HHR Water on the right hand floor
This is my first post here. After reading about 60 or so pages of water leak threads, I have found the responses here on this forum to be of utmost value and commend everyones responses. I have water dripping from the A/C box onto my floor mat and did not notice it until the water began to stand within the foot well. I looked at the cowling under the wipers and noticed the membrane was funneling water from the outside(much like many here have) I repaired the leak as per Snoopy's fix and it did not help. The water only runs out when the A/C is on high (thats all it will work on) and it appears the drain plug for the A/C is not plugged. I am in attempts now of trying to find out where the cabin fresh air filter is but can not. I also saw the TSB for condensation and am efforting that fix as well. Wish me luck.
If anyone can tell me where the fresh air filter is I would appreciate it. OBD. |
this may be total off base, but I use to have a 03 Lancer, sorta like OBD123 said, after rain water would leak from the AC box in the car under the glovebox area, for some reason something would plug up the A/C tube that lets the water out near the firewall, I would have to get like a long nail and poke in it and water would come pouring out, sounds kinda similar but just a thought
My truck rear sliding window is now leaking...but I think that's completely different than this....:roll::lol:
| All times are GMT -5. The time now is 06:21 AM. |
