Water leaks?
Old Jan 12, 2007 | 04:15 PM
  #171
Alot of people have. check out this thread https://www.chevyhhr.net/forums/show...ght=water+leak
Old Jan 12, 2007 | 04:20 PM
  #172
Snoopy's Avatar
Just curious....
How do you know it is leaking on the driver's side? You stated the water accumulates on the passenger floor
Old Jan 12, 2007 | 04:21 PM
  #173
PhxHHR's Avatar
Originally Posted by Snoopy
Just curious....
He says "passenger compartment" which may just mean the interior / cab area? I think that's what he's saying...
Old Jan 12, 2007 | 04:24 PM
  #174
Snoopy's Avatar
Thank you ^^^^^^^
Old Jan 12, 2007 | 04:27 PM
  #175
PhxHHR's Avatar
Thank you ^^^^^^^
De nada, mi amigo....
Old Jan 12, 2007 | 04:40 PM
  #176
dennispro's Avatar
Thanks HillsdaleHHR. After I posted this, I called the service manager to get the scoop on what was leaking. According to him, the windshield wiper motor was not sealed properly to the firewall, so water running down past the wipers was leaking into the drivers side interior. Does this make sense? Bottom line is that they said they got it fixed, and I have new carpet for the effort. The first time I think it was a weather stripping issue, but I'm not sure.
Thanks for all the feedback,
Dennis
Old Jan 12, 2007 | 04:47 PM
  #177
No problem and to the site.
Old Jan 12, 2007 | 04:48 PM
  #178
PhxHHR's Avatar
Yes,
Good to know that they found the cause AND fixed it, as well.
Old Jan 15, 2007 | 12:41 AM
  #179
I just got home from work, glance over at the floor on passenger side, 1/4 to 1/2 inch of water. @#$%^^&!
It's hard to see but just inside the plug you can see a glistening spot. That's water!! WTF!!! How did water get there?? It looked like it was dripping from there which created the wet spot in the next pic, which in turn dripped down creating the puddle on the floor.
I guess I'll see in the morning how bad it really is. These were taken a little after midnight.
Old Jan 15, 2007 | 12:46 AM
  #180
cyberone3's Avatar
i had leaks in the front passenger side only and it was the rubber trim next to the front windows it snaps into a channel and then its double sided taped to the metal well the tape wore off and the water was getting in through there and going down the a piller to the rug check by kick panel first and work from there i used clear rtv sealant in the channel no water leaks in almost 5 months and going
