I do mine at least twice a year.
Originally Posted by RickyO
they shouldn't, but I know who installed them................me! The dealer furnished them later and of course Mr. Fricken Goodwrench is not open on Saturdays...............I work on the road, so I either put up the ugly uinfinished vehicle or install them myself. The install was not too complicated, but on a new vehicle one never knows.
I'd trade out my running boards for the standard trim if anyone is interested. |
Thanks about the inquiries in regards to the running boards. I shouldn't have posted wanting to trade running boards, because I have decided to sell the P.O. S. and it would serve no purpose to swap them out now. The HHR is black and loaded. Anyone want to buy it, feel free to contact me.
thanks, Rick |
Why would anybody wanna buy a POS?
Well I wasn't going to post on this but, Friday it rained so bad that commerical roofs caved in, National Guard closed roads etc. They claim it has not rained that bad in 100 years. Not even with all the hurricanes that run through Florida. Anyways, I have running boards and sunroof and NO leaks. I would say to have take it back to the dealer and have them check the sealing around your door and sunroof. I agree that the running boards DO NOT effect the seal on the door, I bought them after buying the car also. Good luck!
Water problem..
https://www.chevyhhr.net/gallery/fil...9/92150015.JPG,
https://www.chevyhhr.net/gallery/fil...9/92150017.JPG https://www.chevyhhr.net/gallery/fil...9/92150019.JPG For some reason during the rain water goes inside my passanger side, 1st time according to dealership weatherstrips not glued properly, 2nd time It had 2in holes under the car so they filled them up w/some kind of sealant. does anyone have this problem? :( |
water problem
first do you have a sunroof??? ... check if it closses all the way and seals and if it's ok ......second can you see where it's coming from ??? it could be the pass side door window see if it closses all the way ...... third the sunroof drain could be clogged or the door seal could be bad have them check along the firewall or the inlet for the air on the cowl
hope this helps :cool: |
No issues w/ leaking here, and there has been some pretty nasty storms that have blown thru Miami........Katrina, Rita, and Wilma. |
someone on here has had that problem i cant remember who, the capt knows something about some plugs somewhere.
