What’s the name of this piece?
Old Apr 8, 2019 | 12:34 PM
pandamiamilocksmith's Avatar
The rubber bushing of this piece is all worn out. Can anyone tell me what this piece is called. I think it’s part of the steering rack or whatever, but I don’t wanna have to change the whole assembly if I can just change this. Here’s the pic:
Old Apr 8, 2019 | 12:42 PM
letterman7's Avatar
Tie rod end / ball joint. You can replace just that. https://www.detroitaxle.com/shop/ste...vrolet&vmd=HHR
Old Apr 8, 2019 | 01:21 PM
More specifically, it is the outer tie rod. It is NOT a ball joint. The ball joint is not in your picture.
If you're going to replace it (really best to replace both sides) I would suggest looking for a replacement that has a grease fitting so they can be lubed.
Old Apr 8, 2019 | 05:34 PM
Thanks fellas
SD70M2
Mar 8, 2010 05:37 PM
hyperv6
2.0L Performance Tech
21
Feb 10, 2010 09:51 PM
Black Beauty
Nov 26, 2006 07:01 PM
JOEK86
May 3, 2006 01:01 PM
