Why do I keep getting a PO13 Check Engine Light?? Help!!
Can somebody tell me why or help me trouble shoot why I keep getting this CEL?
Thanks |
DTC Description
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit P0011 Intake Camshaft Position (CMP) System Performance P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit P0014 Exhaust Camshaft Position (CMP) System Performance P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation P0017 Crankshaft Position (CKP)-Exhaust Camshaft Position (CMP) Correlation Try a search if you need more info. |
And give this thread a read by clicking the link below....
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/ Thanks for posting up the DTC's George!:thumb: |
Lowboy44 - note that the code p0013 points to a SOLENOID that needs replacing (not a SENSOR - they are two totally different things). Often parts stores suggests replacing the sensor which is incorrect. So make sure you get the SOLENOID - 843de's link points to the procedure for replacing the solenoid(s) as well as the GM part numbers. It's a pretty easy job so can likely be done in your driveway if you have a screwdriver, and a simple set of sockets.
