Why do I keep getting a PO13 Check Engine Light?? Help!!
Old Apr 27, 2014 | 07:55 PM
Lowboy44's Avatar
Can somebody tell me why or help me trouble shoot why I keep getting this CEL?
Thanks
Old Apr 27, 2014 | 10:10 PM
DTC Description
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0011 Intake Camshaft Position (CMP) System Performance
P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0014 Exhaust Camshaft Position (CMP) System Performance
P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P0017 Crankshaft Position (CKP)-Exhaust Camshaft Position (CMP) Correlation
Try a search if you need more info.
Old Apr 27, 2014 | 10:53 PM
And give this thread a read by clicking the link below....
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Thanks for posting up the DTC's George!
Old Apr 28, 2014 | 01:01 AM
Lowboy44 - note that the code p0013 points to a SOLENOID that needs replacing (not a SENSOR - they are two totally different things). Often parts stores suggests replacing the sensor which is incorrect. So make sure you get the SOLENOID - 843de's link points to the procedure for replacing the solenoid(s) as well as the GM part numbers. It's a pretty easy job so can likely be done in your driveway if you have a screwdriver, and a simple set of sockets.
purple people eater
Sep 17, 2016 01:07 PM
TomR00
Nov 18, 2014 01:56 AM
flooprigger
Aug 4, 2013 08:58 AM
jmpnjoe86
Mar 10, 2013 06:13 PM
Scrivs
Aug 7, 2008 10:06 AM
