Windshield Wipers Acting Goofy
Old Aug 8, 2009 | 11:15 PM
urbexHHR's Avatar
Ok...so I noticed this a few months ago, but haven't had a whole lot of heavy rain while driving so it was never really an issue. Anyways, when I put my wipers on the highest setting of intermittent, (the fastest they can go without being on constant) it works normal for a little while, then every once in a while they will just start going constantly without shutting off. After a few minutes they'll go back to normal, and be working intermittently again. So basically it acts like I turn it up faster, but I don't touch anything.
Anyone ever heard of this before, or have any clues what might be the problem? I think maybe I might see about taking it in one day.
Old Aug 9, 2009 | 12:25 AM
oneton's Avatar
When on intermittent they will speed up as your road speed go's up to the point that is so close to high speed it is hard to tell.. Page 3-8 intermittent speed senstive wipers 06 Manual. Also wipers will activat headlamps when turned on page 3-14 Wiper activated headlamps
Old Aug 9, 2009 | 08:17 AM
Yes, when you get up to 55 w/ the wipers set on the position you say, they will work as if they are on at a regular setting.
Old Aug 9, 2009 | 02:38 PM
urbexHHR's Avatar
Really? Hmm...did not know that. I will have to look that over in the manual. I did know that the lights were supposed to come on after 15 seconds of the wipers being on, but mine don't.
And actually...that really doesn't make sense if I have my cruise set, my speed isn't changing...so I don't know why it would start and stop. But I will have to read up on it...
Thanks!
Old Aug 9, 2009 | 06:06 PM
Should be 30 secs after the wipers are turned on, but not sure if they come on w/ the intermittent selection.
Old Aug 9, 2009 | 06:44 PM
urbexHHR's Avatar
I thought it was 15, but I may be wrong....often I am.... I know my mom's G6 does it no matter what setting you have the wipers at, it will turn the lights on. Next time it rains (shortly) I should check.
Old Aug 9, 2009 | 06:57 PM
ecowarrior71's Avatar
A few months before trading in my 06 for an 09 HHR, my speed sensitive intermittent wipers began acting up. The intermittent speed would change for no reason. While at a constant speed the wipers delay was not constant. It was never really dramatic and I often thought that I was going crazy. Since the car was way out of warranty (I drive a lot), I never had it looked at. I haven't read the manual for the 09, but it doesn't seem to have the speed sensitive intermittent function.
Old Aug 9, 2009 | 07:13 PM
urbexHHR's Avatar
If I find time...I may have it taken in. It isn't a huge concern since it doesn't really hurt anything. I would just hate to have something going bad now, that will go bad in a few years that will need to be replaced out of warranty.
Old Aug 9, 2009 | 07:48 PM
Sno White's Avatar
My 2009 does!
Old Aug 9, 2009 | 09:20 PM
urbexHHR's Avatar
Yeah, I just read it...and I see it does say it has speed sensitive wipers.
Oh, and to correct my first post, I did not have the cruise on, I had forgot. It was raining, and I don't use the cruise control in the rain.
