Racing Discussion Race Track Victories - DRIVE RESPONSIBLY
track night
Old Jun 23, 2008 | 08:17 AM
crazysteve's Avatar
track night
13.82@99 this week end, still cant get a 60' worth a crap. had one good 60' and missed third or i would of had a 13.7 or better.
Old Jun 23, 2008 | 12:13 PM
white heat's Avatar
Nice. Practice, practice, practice. You'll get there.
Old Jun 24, 2008 | 10:25 PM
boosted5038's Avatar
not bad. is this on stock tires? i wonder if mickey thompson makes a drag radial to fit these things. what did it run bone stock before the tune?
Old Jun 25, 2008 | 08:21 AM
crazysteve's Avatar
This was a run on BFG drag radials 225/45/17...(didn't see that big of a difference) I have yet to run it stock so I couldnt tell ya.
Old Jun 25, 2008 | 10:09 AM
z28nate's Avatar
can we use the no lift shift without comp mode???
Old Jun 25, 2008 | 10:27 AM
what were your 60' times? i found that mickey t. does make a slightly wider drag radial than the stock tires. huge difference between bfg and mickey t's. were you bang'in the piss out of it through the gears the tune you have puts the boost up around 23lbs or so?
Old Jun 26, 2008 | 09:07 AM
crazysteve's Avatar
my 60's are crap usually around 2.30 had one good one at 2.17 and missed 3rd, I turn off tcs and used the no lift,
Old Jun 26, 2008 | 03:50 PM
ColeTrickle's Avatar
Nice time....
I was hoping to see a little more mph. what was the DA and what pressure did you run in the drag radials?
Old Jul 18, 2008 | 10:10 PM
mightymouse's Avatar
i think the biggest problem with the hhr ss is the fact they are porky. when i had my srt back in 04,i was able to and everyone else i knew cut a 13.9-14.1 stock!!! now i know the srt-neon is about 400-500lbs lighter,but this motor have way more hp stock than the srt. i'm hoping to pull a 13.8 on drag radials stock. i'm not going with 17's. i need to check the bolt pattern,but if i can get my wifes old stock corolla rims on blackout with some 16 inch drag radials,i think it's possible. with tune i think 13.4-13.0 is doable. however it's all in the launch and the 60'ft. then again,i'm at sealevel,so maybe i will have better luck...
Old Jul 19, 2008 | 10:22 AM
crazysteve's Avatar
I dont think you will see a 13.8 stock unless you gut the car, the biggest problem that I am running into is that even when the TCS is off it still will cut power on launches but is does not do it all the time...explains my 2.17-2.60 60' times
