Front clip assembly
Old Nov 20, 2011 | 01:23 PM
RICKYVB's Avatar
Front clip assembly
FRONT CLIP ASSEMBLY
I searched all over the internet for this diagram. Now, that I found it. I figured I would share it with you guys/gals here.
Click the image for the full size version of the image.
Part numbers below...
CLICK THE BELOW INFO TO VISIT THE SITE WITH THE PARTS
Index Stock Code Description Price
001 25913641 BAR. Front and Rear Bumper/Fascia Face
BAR,FRT BPR IMP. Required: 01For: A (2006-2011) (2006 - 2011). $147.92
002 11570654 CLIP; NUT; RETAINER; WASHER. NUT. RETAINER. CLIP. Instrument Panel. Instrument Panel Pad. Bumper/Fascia. Front and Rear Bumper/Fascia Face.
$3.60
002 11518531 NUT. Door Lock Inside Handle. Front Door Trim. Inflatable Restraint System. Instrument Panel Pad. Rear Compartment Lift Window / Lift Gate / End Gate. Rear Side Door Trim. Rear Side Door Trim Finish. Vehicle Navigation/Information.
$2.22
003 15827789 BRACKET. Bumper/Fascia
BRACKET,FRT BPR FASCIA(TO FDR FRT) - LH. Required: 01LHD. For: A (2006-2011) (2006 - 2011). $5.63
003 15827790 BRACKET. Bumper/Fascia
BRACKET,FRT BPR FASCIA(TO FDR FRT) - RH. Required: 01RHD. For: A (2006-2011) (2006 - 2011). $5.59
004 11609489 BOLT. BOLT. Capsule/Headlamp/Fog Lamp Mounting. Floor Console. Front Fender Inner Wheel House. Instrument Cluster. Instrument Panel Compartment Door. Instrument Panel Gage. Instrument Panel Pad. Radio Mounting. Rear Wheelhouse. Steering Column Attaching. Windshield Defroster.
$0.88
005 15828913 BRACE. Front and Rear Bumper/Fascia Face
BRACE,FRT BPR FASCIA - LH. Required: 01LHD. For: A (2006-2011) (2006 - 2011). $4.92
005 15828914 BRACE. Front and Rear Bumper/Fascia Face
BRACE,FRT BPR FASCIA - RH. Required: 01RHD. For: A (2006-2011) (2006 - 2011). $4.92
006 11513599 BRACKET; CLIP; NUT; RETAINER. NUT. Instrument Cluster. Floor Console. Bumper/Fascia Mounting. BRACKET. CLIP. A/C Vacuum and Temperature. Brake Pedal. Bumper/Fascia. Exhaust Tail Pipe.
$5.00
007 11513599 BRACKET; CLIP; NUT; RETAINER. NUT. Instrument Cluster. Floor Console. Bumper/Fascia Mounting. BRACKET. CLIP.
$5.00
008 11589015 BOLT. BOLT. Air Distributor. Air Outlet. Floor Console. Front Door Trim. Inflatable Restraint System. Instrument Panel. Instrument Panel Compartment Door Lock and Console Compartment Door Lock. Radiator Grille and Front End Panel. Radio Auxiliary Speakers. Windshield Reveal Molding.
$0.68
009 25913645 BRACKET. Bumper/Fascia Mounting
BRACKET,FRT BPR IMP BAR(BOLT-ON CMP OF IMPACT BAR ASM) - RH. Required: 01RHD. For: A (2006-2011) (2006 - 2011). $22.19
009 25913646 BRACKET. Bumper/Fascia Mounting
BRACKET,FRT BPR IMP BAR(BOLT-ON CMP OF IMPACT BAR ASM) - LH. Required: 01LHD. For: A (2006-2011) (2006 - 2011). $22.19
010 25536302 NUT; RETAINER. NUT. RETAINER. Bumper/Fascia Mounting. Front and Rear Bumper/Fascia Face. A/C Instrument Panel. Air Cleaner To Carb/Throttle Body Mounting. Air Distributor.
$4.39
011 15827749 BRACKET. Front and Rear Bumper/Fascia Face
BRACKET,FRT BPR FASCIA SI(FASCIA/FENDER SI) - LH. Required: 01LHD. For: A (2006-2011) (2006 - 2011). $6.09
011 15827750 BRACKET. Front and Rear Bumper/Fascia Face
BRACKET,FRT BPR FASCIA SI(FASCIA/FENDER SI) - RH. Required: 01RHD. For: A (2006-2011) (2006 - 2011). $6.10
012 11609489 BOLT. BOLT. Capsule/Headlamp/Fog Lamp Mounting. Floor Console. Front Fender Inner Wheel House. Instrument Cluster. Instrument Panel Compartment Door. Instrument Panel Gage. Instrument Panel Pad. Radio Mounting. Rear Wheelhouse. Steering Column Attaching. Windshield Defroster.
$0.88
013 11570082 BOLT. BOLT. Air Injection Reactor Pump and Multi-Function Air Compressor. Brake Flange Plate. Child Safety Seat. Distributor. Emission Control System. Engine Camshaft. Engine Lift. Engine Oil Cooler. Engine Oil Pan. Fuel Tank Mounting Strap. Hood Latch. Instrument Panel. Intake & Exhaust Manifold. Parking Brake Cable. Seat Belt. Shock Absorber/Strut. Transmission Control. Transmission Control Lever. Transmission Oil Filler. Transmission Oil Pump. Transmission Shift Control. Transmission Shift Control Lever. Turbocharger/Supercharger Cooling. (also Knock Sensor)
$1.38
014 22714709 COVER. Front and Rear Bumper/Fascia Face
COVER,FRT BPR IMP BAR FOG LP ACC HOLE(W/O FOG LAMP) - LH. Required: 01LHD. For: A (EXC DELUXE FOG LP(T37) (2006-2009) (2006 - 2009). LHD. For: AS,AT (... Show More $70.37
014 22714710 COVER. Front and Rear Bumper/Fascia Face
COVER,FRT BPR IMP BAR FOG LP ACC HOLE(W/O FOG LAMP) - RH. Required: 01RHD. For: A (EXC DELUXE FOG LP(T37) (2006-2009) (2006 - 2009). RHD. For: AS,AT (... Show More $70.37
015 15875482 LAMP. Chassis/Body Marker/Hazard
LAMP,FRT SI MKR - LH. Required: 01LHD. For: A (2006-2011) (2006 - 2011). $16.13
015 15875483 LAMP. Chassis/Body Marker/Hazard
LAMP,FRT SI MKR - RH. Required: 01RHD. For: A (2006-2011) (2006 - 2011). $15.30
017 15269707 FASCIA. Front and Rear Bumper/Fascia Face
FASCIA,FRT BPR. Required: 01For: AS,AT (2006-2011) (2006 - 2011). $390.80
018 22714706 DEFLECTOR. Bumper/Fascia
DEFLECTOR,FRT BPR FASCIA AIR. Required: 01For: A (2006-2011) (2006 - 2011). $87.33
019 22714712 GRILLE. Radiator Grille
GRILLE,RAD LWR. Required: 01For: A (2006-2011) (2006 - 2011). $79.54
021 22638717 BOLT; RETAINER; RIVET. RIVET. RETAINER. Front and Rear Bumper/Fascia Face. Front Fender Inner Wheel House. Radiator Baffle and Shroud. BOLT. Radio Mounting. Air Cleaner Intake. Auto. Bumper/Fascia. Fender Wheelhouse. Floor Console. Front Fender. Fuel Tank. Fuel Tank Filler. Instrument Panel. License Plate. Radiator and Front End Tie. Rear Seat Back. Rocker Panel Molding. Running Board.
RIVET,FRT LIC PLT BRKT(4.85MM DIA). Required: 04For: A FRT LIC PLT MTG PKG(VK3) (2006-2011) (2006 - 2011). $0.72
022 22714704 BRACKET. License Plate
BRACKET,FRT LIC PLT(4 ATTACHMENT SITES ON BRKT TO AFIX BRKT TO FASCIA). Required: 01For: A FRT LIC PLT MTG PKG(VK3) (2006-2011) (2006 - 2011). $18.44
023 15798573 ABSORBER. Bumper/Fascia Energy Absorber
ABSORBER,FRT BPR FASCIA ENGY. Required: 01For: AS,AT (2006-2011) (2006 - 2011). $115.83
024 25631448 BOLT. RETAINER. Bumper/Fascia Energy Absorber. Front and Rear Bumper/Fascia Face. Bumper/Fascia Mounting. Rear Compartment Trim. Bumper/Fascia.
BOLT,FRT BPR ENGY ABS(7.2 DIA,22.0 O.D.,30.75 LG)(W/#3 SQ ROBERTSON DR)(07.831). Required: 02For: A (2006-2011) (2006 - 2011).
Old Nov 20, 2011 | 01:38 PM
Sure it will come in handy for another owner, thanks for posting it!
Old Nov 20, 2011 | 08:49 PM
RICKYVB's Avatar
Your welcome!
I was not sure where to post it. So, I figured General HHR, would be a good spot to not get yelled at!
Old Nov 20, 2011 | 10:33 PM
You won't get yelled at here Ricky, but you might find the local villagers outside your gate with pitchforks and flaming torches.
Or even worse, an angry mob of minor characters from the Simpsons.
Old Nov 21, 2011 | 12:59 AM
RICKYVB's Avatar
lol
XtremeSS
Aug 27, 2023 03:05 PM
jeffros hhr
Oct 10, 2019 08:35 PM
mcgrosjr
Drivetrain (Excluding Engine)
Apr 24, 2013 11:44 AM
cfriske
Oct 9, 2011 12:02 AM
Vandan
May 21, 2010 09:08 AM
