Evap problems
Old Jan 12, 2018 | 05:05 AM
Ron Mullholand's Avatar
Evap problems
My 2010 HHR with a 2.4 engine is throwing two codes po171 and 496 and I've already changed the evap canister solenoid what do I do next
Old Jan 12, 2018 | 05:50 AM
Welcome
The problem could be that you're writing the code incorrectly. It is P0171.
P codes are followed by 4 numerals (not a small case letter "o" like you posted)
Search the correct codes on this site and you'll see many related threads.
Be sure to set the Search window to Google Search.
Old Jan 12, 2018 | 08:45 AM
Usually means the EVAP purge valve (the one under the hood).
Old Jan 12, 2018 | 09:01 AM
Welcome to the site,
P0171 code points toward a dirty MAF sensor, a cracked flex pipe or clogged catalytic converter per
https://www.obd-codes.com/p0171
I suggest you go systematically and look at one thing at a time, my money is on the flex pipe.
P0496 pertains to the evap Solenoid and or the evap canister
Per
https://www.obd-codes.com/p0496
Old Jan 12, 2018 | 09:45 AM
Well, not exactly. If the purge valve is stuck open (p0496 purge flow when commanded off) you can get a P0171 (too much air in the A/F). And hard starting.
The terminology used for the valves is very confusing, that's why I try to define which one physically. Sometimes the purge valve (under hood) is called the charcoal canister purge valve/solenoid and the other one is called charcoal canister vent valve/solenoid.
Old Jan 12, 2018 | 10:18 AM
Im just pointing towards causes and solutions, check the flex pipe, test the under the hood EVAP Solenoid
If you can blow thru it , replace it.
Old Jan 12, 2018 | 01:15 PM
aradmahogany's Avatar
Are you running any sort of cold air intake system or have you modified the intake system in any way?
CDS31MC
Mar 24, 2023 09:00 PM
2007HHRLT
Feb 8, 2013 07:17 PM
Diskokid
Nov 11, 2012 01:33 PM
asanti
May 29, 2011 03:29 AM
RETRO-RED-EXPRESS
Feb 8, 2011 10:13 PM
