Alternator---how many amps?
Old Oct 26, 2007 | 02:09 AM
Copperhead's Avatar
Anyone know the answer to this? Also since a GM alt., it should be able to be rebuilt to deliver more, right?
Old Oct 26, 2007 | 06:00 AM
WhiplashHHR's Avatar
I don't know how many amps, but why do you need more amps? It's plenty if your just upgrading a stereo or adding a amp.
Old Oct 26, 2007 | 06:58 AM
courthousedeb's Avatar
You asked the same question about this time last year...here's that thread with info you should need.
https://www.chevyhhr.net/forums/general-hhr-4/chrysler-group-give-free-gas-car-317/
Old Oct 26, 2007 | 08:28 AM
Black Rose's Avatar
https://www.chevyhhr.net/forums/showthread.php?t=317
Deb, you left a "7" off of the url.
Should be https://www.chevyhhr.net/forums/audio-video-17/alternator-how-many-amps-3177/
Old Oct 26, 2007 | 09:52 AM
betterof2evils4's Avatar
Instead of a redirection, I'll just tell you that it is 130 amps according to Chevy's website. I've been looking into this as well, but if you happen to get it done first, you gotta post results, dude!
Old Oct 26, 2007 | 09:55 AM
Yea, for low-medium wattage systems. I had 1800W running with a mono-channel amp and a 2 farad cap and it still drained my battery. Also, I'd say this is a better way to go than adding a second battery because that's just more load that you put on the alternator.
Copperhead's question signifies to me that he has bigger plans, and wants to do it "right."
Old Oct 27, 2007 | 01:52 AM
Copperhead's Avatar
And your point!? If I had been able to find that thread I wouldn't have asked it again. Not all of us have had decent computer to rely on.
Old Oct 27, 2007 | 01:55 AM
Copperhead's Avatar
Thanks for giving me a straight answer.
Old Oct 27, 2007 | 10:06 AM
I was just trying to be helpful...sorry if you feel the need to cop an attitude about it. And...it doesn't have anything to do with having a "decent computer" it's all about getting lucky enough to get the right search terms, I used alternator amps (just forgot to add on the last 7 on the link, for which I apologize.)
In the interest of trying to help you once again...if you know you started a thread, the easiest way to locate it is to click on your username on a thread and view your own profile. Then you can click on view posts started by copperhead and all the posts you started will be there. You can also click on My Posts at the top of the forum and look through those as well...there is only 35 to look through.
Last edited by courthousedeb; Oct 27, 2007 at 10:07 AM. Reason: correct spelling error
Old Oct 27, 2007 | 10:53 AM
SindyDix's Avatar
Here is the correct link referenced above:
I hope this helps as well.
Alternator,..how many amps?
Well duh, I see that was also mentioned above!
speedywannarace
Aug 27, 2013 07:49 PM
Copperhead
Sep 5, 2006 09:44 AM
XTRMEASURES
Jul 25, 2006 06:47 PM
