rear levelers and 20s
Old Nov 3, 2007 | 05:03 PM
SLVR FOX's Avatar
anyone have this setup?
im getting 20s soon and want to drop my hhr, but im affraid of the GL springs setting me too far down.
if i can get a good look with the GL leveler springs, then i would rather go that route.
Old Nov 3, 2007 | 05:05 PM
Do a search for leveling springs and you'll find a few threads with plenty of pics.
Old Nov 3, 2007 | 10:16 PM
SLVR FOX's Avatar
thanks, but i couldn't find anyone with the levelers and 20s.
basicly wanting to know if i go with the rear only if i can get a bigger sidewall.
like instead of 235-30-20 i can get a 225-35-20 and still look lowered.
Old Nov 3, 2007 | 10:34 PM
chingchonger's Avatar
When getting low sidewall tires, it will exaggerate the tire to fender gap and visually make the car look raised. So if you're going with 20's, you better drop it low. 225/35/20 has only an 8.25mm higher sidewall height versus the sidewall height of 235/30/20. It's consider to be virtually the same.
It may fill in the gap just a bit, but not noticeable. Your car will look raised even with the rear leveling springs.
If you're going to lower your car, you will need to trim or roll the rear fender. If you have a 2007 model, you may not need to since the rear fenders come slightly pre-rolled. This is only the case if you go with a 225 width tire with the correct offset. If you go 235's then you NEED to roll/trim the rear fenders.
Old Nov 7, 2007 | 07:40 AM
WhiplashHHR's Avatar
I have leveling springs and 20's. The ride of the springs are great with stock tires and on the 20's you feel just about everything in the road.
Old Nov 7, 2007 | 07:58 AM
O6ChevyHHR's Avatar
post pis when its all on! Should look sweet!
Old Nov 7, 2007 | 08:23 AM
SLVR FOX's Avatar
whiplash- do you have any pics of your HHR with the levelers and 20s?
also, what size tires are you running?
Old Nov 9, 2007 | 11:26 AM
I have 2 pictures in the picture section. But I'll get get some new ones up for you today. Also I'm running a 225/30 tire.
Old Nov 12, 2007 | 09:28 PM
Uma's Avatar
Uma
Real Nice setup you have there! Looks great, a little familiar, but still great, I went a little taller tire on the 20" DIPS. I had the lower sidewalls, but changed them to fill the gap a little better. Your car looks great!! Todd (Uma
Old Nov 13, 2007 | 06:25 AM
SLVR FOX's Avatar
Uma-yours is leveled with 35 series tires?
any rubbing?
