Hooking up a better sub: Question on Line level/output converters!
Old Dec 4, 2007 | 11:23 AM
PhoS's Avatar
So I need some more bass then the stock unit can provide me so i'm grabbing a 12" kicker stuff back there. I will be using a Kicker 400:1 amp for some punch.
My question is:
I fully intend to leave the stock premium deck alone regardless of how craptatcular it is and from what I understand I can use a line level/output converter to pull a signal to convert to RCA from the stock sub's lines right?
This is what I was looking at:
http://www.crutchfield.com/App/Produ...rter&i=142SLC4
Will this work for what I need to do?
Will I run into any problems with hissing , interference etc?
I plan on installing a remote line level controller as a makeshift volume control for the sub since I adjust it all the time anyway. Any insight would be much appreciated
Old Dec 4, 2007 | 01:28 PM
PhoS's Avatar
I just saw that thread above about splicing in to the stock wires I think im going to give that shot first :p
Old Dec 4, 2007 | 07:23 PM
Navyflyer11's Avatar
That will do the job. I use a line level converter similar to that for mine in the beginning.
garagebuilt
Jan 15, 2010 08:25 PM
spirited driver
13
Apr 27, 2009 02:09 PM
joshua_arndt
Sep 26, 2008 07:38 PM
WhiplashHHR
Oct 20, 2007 08:28 AM
