Rear Speakers and Sub Not Working?
Old Feb 1, 2008 | 08:07 PM
Ween's Avatar
My rear speakers and sub are very very quiet unless I turn the stereo wide open and move the fader to the rear with all but 2 notches left. This seems really wrong to me. Anyone have a clue if this is normal or if it sounds like maybe the amp for the rear is not working. Is the amp only attached to the sub, or is it attached to the rear speakers as well. Any advice would be appreciated.
Old Feb 1, 2008 | 08:19 PM
1Panel2NV's Avatar
That's how mine was. Every once in a while I would get a song where I could hear some bass, but not often. A 12'' sub solved that problem though.
Old Feb 1, 2008 | 08:24 PM
Ween's Avatar
What about the speakers in the rear door panels. Does it seem right that when the fade is in the middle you cant hear them at all when sitting in the back seat?
Old Feb 1, 2008 | 08:35 PM
1Panel2NV's Avatar
There might be a problem if you can't hear the door speakers. Not really sure what would cause it though.
Old Feb 1, 2008 | 08:37 PM
Ween's Avatar
You can hear them barely with the fade all the way in the rear and the volumn turned half way up. So now that this sounds positively fishy, I wonder what the culprit is. It definately sounds like an amp issue. Whether thats internal to the head unit, or external somewhere I dont know. I don't know how the hhr does its stereo equipment.
Old Feb 1, 2008 | 08:58 PM
oneton's Avatar
Put your head down where the speakers are you will hear them. They are in a s--- place. are the speakers in the same place in a panel as a rear seat if so they must be covered up like when I have my rear seat down. like all the time
Old Feb 1, 2008 | 09:03 PM
Ween's Avatar
Are you telling me that what I hear is normal? If so, I feel robbed by paying anything extra for this radio. I wonder if I could get a refund :). I need a nice avic-d3.
Old Feb 1, 2008 | 09:10 PM
1Panel2NV's Avatar
My rear door speakers seem to work fine, but yes the "premium" system isn't too great. I guess you also get the advantage of being able to add subs easier since the wiring is already there.
Old Feb 1, 2008 | 10:00 PM
Ween's Avatar
Does anyone have any idea what powers what... or maybe what may be wrong?
Old Feb 1, 2008 | 10:12 PM
1Panel2NV's Avatar
The amp powers all the speakers I believe. It's located behind the driver side rear panel. You can see part of it if you remove the cover to get to the tail lights. I'd take it to the dealer and see what they will do if you want to keep it stock. Otherwise it's not really worth messing with unless you add you're own amp and speakers.
