Sub questions.
Old May 3, 2008 | 02:43 PM
jameswattsjr's Avatar
Sub questions.
I have a 2007 hhr and it has the factory sub in it. Have several questions.
If I put a stronger amp on factory sub will it hit harder. Or would it be best just to replace sub and amp to get harder hitting base. I am interested in fosgate sub, anyone put one in their hhr. If so what model. Anyone know how mush air space is in factory box?
Old May 3, 2008 | 04:20 PM
prod's Avatar
Most of what you need is in the sticky threads at the top of this forum. From what I remember: the factory sub is 2ohm, so you could replace it with another 2ohm 8" sub, but that wont get you much. You could switch to a 10", a couple members have done so, but the amp doesnt give it much power, so that could be re-worked. And you need to modify the factory box or make your own to fit in the same space, that can be tricky. It is only .3 cubic feet or so, about 4 inches deep and oddly shaped.
The most bang for your buck is to add an amp and large box in the cargo area, but then you might need to remove it to carry cargo. Id go for dual 12"
Old May 3, 2008 | 05:16 PM
Ed RazorLite's Avatar
The factory sub wont handle any more power than the factory amp. Also the factory sub is meant to work in the factory enclosure and most aftermarket subs wont work as well in the factory enclosure. So the best way to upgrade is to add a new amp, new box, new sub.
Danman03
Mods - Exterior
13
Feb 10, 2015 01:24 PM
Oscarvan
Feb 19, 2013 06:41 AM
saxrocks2009
Apr 1, 2010 01:10 PM
Newsvt
Mar 19, 2009 04:51 AM
Belto
Apr 16, 2008 07:09 PM
