Upgrading your stereo but keeping factory head unit
Old Jun 14, 2008 | 07:58 AM
Stumpy Knucks's Avatar
Red face Upgrading your stereo but keeping factory head unit
Does anyone know if there is a converter on the market so that your able to keep your factory stereo headunit but be able to hook power amps to it?
Old Jun 15, 2008 | 11:52 AM
jbbadboy's Avatar
I've got the factory head unit in my HHR and have added a Kicker box, Rockford Fosgate amp and cap to the system with no problem. A friend of mine did all the work for me and I believe he spliced into the existing wiring so it can be done. I wish I could tell you more.
You may have more luck if this thread was in the audio section. I'm sure someone will post with more info for you.
Old Jun 15, 2008 | 12:28 PM
08hhr's Avatar
its known as a line out or high level out they will run you around 20 bucks
Old Jun 15, 2008 | 01:39 PM
Old Jun 15, 2008 | 01:45 PM
Always refer to your original thread instead of making a new one on the same topic. Thanks
shaginwgn's Avatar
If you have the premium system check this out https://www.chevyhhr.net/forums/audio-video-17/how-hook-up-amp-sub-woofer-setup-without-affecting-existing-premium-sys-10944/
Old Jun 16, 2008 | 05:33 PM
knightRS32's Avatar
This weekend I spliced a line output converter into the rear speaker wires off of the head unit. From the converter I was able to run the RCA cable back to the amp. I put in a 12 year old PPI APA100 amp on a 6 year old JL Audio 10" in a truck wedge box...it definitely thumps pretty hard!
If you do a line output converter there are two filter screws on it that are most likely turned all the way up so you get a lot of distortion at low volume. Make sure you leave out the head unit when you adjust the amp so you can adjust the converter as well. I had to pull the dash components twice....
Old Jun 17, 2008 | 05:27 AM
Thank you!!!!
Old Jun 17, 2008 | 03:43 PM
crazysteve's Avatar
Rockford makes these very cool
http://www.rockfordfosgate.com/produ...s.asp?cat_id=1
teknolla
Feb 5, 2019 04:01 PM
SpaceCowboy
Mar 6, 2018 04:32 PM
Curmudgeon
May 10, 2007 04:53 PM
