Pillar Removal??
Old Oct 31, 2008 | 09:54 AM
richie6's Avatar
Pillar Removal??
Anyone change the tweeters in the pillars?? How did they come off and what tweeters did you use??
Old Nov 3, 2008 | 12:32 PM
richie6's Avatar
No one knows how to remove the front pillar to replace the tweeters???
Old Nov 3, 2008 | 01:34 PM
hugheshhr's Avatar
there is a screw or bolt dont remember which at the top and then they just pop off. i used exile tweeters in mine. had to trim the tweet a lil tho.
Old Nov 3, 2008 | 02:33 PM
Just pop out the oval plug and there is a torgue bolt. Then it's real easy.
Old Nov 9, 2008 | 09:49 AM
collyn's Avatar
I cut mine out with a Bluepoint mini air saw....then I fiberglassed in some 4x6" waveguides for my JBL tweeters. definately not a DIY for the average person. But, if you just want to replace, a T-20 torx driver and a 7mm(if I remeber right) is all that is needed to remove the factory static maker. the inside of the pillar is molded to fit only a factory tweeter, so some slight mods are needed to fit an aftermarket tweeter there. You will have better results with a hole saw and flush mounting the new tweeter from the surface into the pillar. The holes molded into the pillar as a "grille" are too small and far between to allow the correct radiation pattern from the tweeter. This causes near side bias and irratic frequency response. The same defonately holds true for the door locations as well. The aftermarket speaker sits flush into the door sheetmetal about 1.75" inches behind a slightly offest group of poorly executed holes. The sound from the aftermarket speakers is mostly directed into the INSIDE of the door panels and makes imaging and frequency response suffer. It also causes the door panel to vibrate giving off sympathetic vibrations and imaging cues.
But...it looks factory :)
Old Nov 9, 2008 | 11:42 AM
Tuanies's Avatar
Do you have pics of the tweeters? I put Kappa's in my car and currently using stock locations, its a tiny hole and I've been debating taking a hole say to it to mount them properly, but worried about how it'll look.
Also any suggestions on mounting the woofers in the doors? Although they sound better than factory, the frequency response still isn't right :-\.
Old Nov 9, 2008 | 12:26 PM
stick's Avatar
I used Rockford Fosgate in mine that came with the component set I bought.
Old Nov 9, 2008 | 12:27 PM
stick's Avatar
I just used a knife to cut out the old covering and used the mounting hardware supplied to mount the new ones too.
Old Nov 9, 2008 | 05:11 PM
Tuanies's Avatar
Yea, the Kappa tweeters are quite a bit larger than the factory ones...
bartSS
Apr 4, 2011 07:07 AM
HHR_SS_QC
Apr 17, 2009 01:41 PM
